well, the interiors been in for a short while so i guess i better get some build pics up.
I have based the build on 18mm moisture resistant MDF for the fronts and 9mm ply for the carcase. It does not matter what you use for the fronts as long as you can lip the edges with a t trim, in this case i have used 18mm trim, you could use 15mm finished ply for example and a 15mm trim.
I started with the og interior as a template for all the carcase measurements.
Then got to work with some measuring
Front cut out with a router and jigsaw.
Next job was on to the doors, these are bigger than the original doors as they will sit face mounted when fitted.
Pic shows the groove being cut for the t trim.
now for the Carcase,i have cut all the panels first so its now a case of assembly.
once your this far the rest is a bit more pleasurable (as its a bus mans holiday for me) as its time for trim and finishing.
Firstly the mdf is given a coat of pva to seal it against any nasty damp :evil: :x
now the fun bit, paint and grain then two coats of varnish :mrgreen:
Then on to the trims
rubber mallet a must
which all should end up looking like this.
More to come soon :mrgreen:
