Under seal
I used this product once I treated the areas under my bus with a rust gel. hammerite Worked well and was a wax oil mix. Stone chip is ok but not long lasting. Another product is Dinitrol which is a very good product through a gun. Have a look at some reviews.
Cheers I’ll have a look.
Looking for something to protect it but don’t want it to look like it’s been coated thick with under seal.
Is it best to etch primer it first?
I like the Bilt Hamper products, easiest and best stuff I've ever used.
Thanks for the recommendations I’ll have a look into them. I’ve got a mix of new metal and old. I’m in the process of removing all old underseal and rubbing down any surface rust.
Am I still best of putting a primer on first or will most of this stuff not require a primer. I like the idea of doing it body colour underneath but not sure the best way to go about that.
Same situation, old and new metal to protect,I can only say what I did.
I bought a set from Frost’s, once all the gunk was removed from the underside there was a degreaser, a metal prep and then the final coat
Heres my process.
Old underseal off
Epoxy prime
Seam seal
Stone chip
2k paint.
