It's difficult to say, It was made up of:
Some new bits I supplied (case, B&P's, serpentine kit, cooler)
Old bits I supplied (heads which got stainless ex valves, carbs (which Laurie re-jetted for me), manifolds, linkage, dizzy, coil, leads, tinware, fuel pump, filter head, push-rods, heat echangers, silencer and tail pipes)
Some used parts Laurie supplied and had machined where needed (wasser crank (still not ground), 228mm T4 flywheel, rockers, T1 con rods, dizzy drive etc)
Some new parts Laurie supplied - (cam kit, clutch kit, bearings, hoses and fittings and lots of other bits and bobs).
I went up and did a good deal of the swap myself and dumped the old beetle SP engine on him minus the alternator and a few parts for a little money off.
Plus Laurie's me mate innit.
I believe if you had to source all the parts and sat on arse waiting you'd be looking at £3.5K for a similar engine. Almost as much as I paid for the bus. :shock:
There are other ways to do it eg with a new stroker crank rather than the wasserboxer one, but I asked Laurie to do whatever he wanted and relied on his experience to come up with an engine that I'd like. Originally I wanted him to source everything (he wanted me to source everything) so it wouldn't be my fault :lol: but as the bills started to mount up I stripped a perfectly good TP engine for the heads and peripherals to build it up and probably saved £1k on parts. I haven't added up the cost as there's little point, but I wouldn't have got £1k for the TP engine and I've still got the end-float free engine minus the heads to sell and already sold the stainless exhaust system that was on it too.
So you see it all depends what you have to start with. I could have saved £600 by asking him to use the case (re-worked engine shop case) I stripped the parts off, but he might have found it machined to the limits or who knows what problems, so to take the doubt out of it and possibly save going round in expensive circles before ending up with a new case anyway, we agreed on building it round a new case. It gives me a lot of confidence knowing the case is new, crank just needed a polish, mex heads are good of their type, new cam kit, new B&P's, but all the bolt on the outside parts are worth a risk if you already have them I guess.
