Now the bus is tucked away in the carport,I've decided to have a go at fixing it
It has only showed up twice so will be tough to track down
It clicks the solenoid and won't spin over ,tried a jump battery still the same ,both times when it was hot
Before I could get under to give it a whack and check the terminals on the starter,it cured it self and hasn't done it again since
I've read either bad wiring,a worn bush on the end of the starter pinion, or a duff motor
Are any of those 3 things common?
Matt
Matt
