terrier man
Wannabay said:i have same poblem with gear stick coming loose
does the loctite, 2 spanners advice work?
and how smooth is your gear change? mine is quite 'notchy' albeit more positive than the original stick
gerry
I have the mkI version which were more expensive, the shaft is welded into position & are also handed.
I would use Loctite 638 on threads if you can get it does go off very quickly if that don't work nothing will.
As for your notchy shifting try the thiner stock shifter lock out plate instead of the much thicker one supplied.
