My last "new recon block new internals" motor with totally stock setup,oil bath airfilter,34 pict 3 carb,stove pipe and thermostat and flaps etc used to weep after it had been for a run.
Now i have a new replacement block again with stock setup and this too is weeping from the oil breather pipe!
Could this be because the oil in the airfilter is too high and working it's way down the pipe and then out under pressure?
Or is it something else?Or have i missed something??
Strange how two engine are doing it or is it normal??
Regards.
Sharky.
Regards.
Sharky.
