:mrgreen:
I’d cut back a little mor first then clean up inside and out. I’d then make a plate bigger than the hole then cut that in half to slip inside the hole and hold them there with magnets then tack, then fit a plate in the hole then tack, then turn up the heat a bit and weld right through but just a bit at a time, then your sure you’ve got a lot more steel then you started with.
Ozziedog,,,,,,,,,,,, you can then buff to invisible :mrgreen:
