Bobster said:http://forum.earlybay.com/viewtopic.php?f=4&t=60345
In the end I went for these which were more domed ...
http://www.ebay.co.uk/itm/271010747542" onclick="window.open(this.href);return false;
trebor said:Bobster said:http://forum.earlybay.com/viewtopic.php?f=4&t=60345
Did you have to get the wiring connectors as well ?
trebor said:Cheers, thought you might have to get a multi plug or something for the back of the bulb.
Graham L said:trebor said:Cheers, thought you might have to get a multi plug or something for the back of the bulb.
The multi plug for the headlamp is already there on your bus Bob
Marriedblonde said:I bought these for mine:
http://www.customandcommercial.com/vw-baywindow/lights--and--lenses/headlamp_parts/german_quality_complete_hella_headlamp_units_rhd_pair_68-12fslash73_10297/" onclick="window.open(this.href);return false;
I believe they are just beetle headlights though.
Graham L said:You have to be careful as US lights are completely different to UK RHD ones, the simplest solution is to fit Late Bay /Golf MkII headlights as they come with the correct mounting framework etc, I've bought other lights in the past and the time its taken to modify them to fit outweighs the fact they might be cheaper in the first place, the biggest issue is that because the US lights didnt have sidelights in them you usually have to cut away part of the mounting framework to allow access for the sidelamp holder.
jimbo4861 said:Thanks Graham and Bobster
But mine is a rhd so already has sidelights in headlight will the ones Bobster bought be ok ?
