why do my wheels never fit
69PROJECT
Jul 18, 2009
233
i know there are some simple answers to this but im on my third set of rims and none will go under the arch
its a 68 bay with horseshoe plates fitted at the moment no spline adjustment yet
i tried radars but castle bolt and spacers meant it was a no no....
so i tried american eagles but being 5.5 they were too wide...
now have a set of brms(5" i guess)....
these obviously fit better but ive just tried 175/55 and the tyre still rubs!
i have 165/50s for front but if im getting desperate at the rear
i saw a split in a magazine recently with 165/80s recently but wary of buying a set of tyres that dont fit!
any ideas??????????????????????????
at this rate ninove wont be happening! :msn4:
Simon
Do a search on the internet for wheel offset and make a brew and do a little reading.
In short, most alloys have a crap offset hence why you get into problems, once you understand rim width and offset you'll be able to work out what you need ;)
matt the brms fit,its just the tyres that rub :x
mattp said:
IIRC they also have a shite off set -sommit like ET12
yep all rims seem to be bus unfriendly
just seen a thread that ash(dubscum) had some 165 80s so going to mail him as i cant afford another set of rims
Read up on ET and understand rim with and the difference in with from say, a stock 5.5j rim to an alloy 5.5j
It is straightforward, you just need to find something similar to stock. Understanding this allowed a friend to fit 9j rims with monstor tyres on his slammed bus, no running on springplate or arch (Porka rims in case you were wondering)
i get what you are saying but have no pounds to spend on another set of rims....
We have brms fitted with toyo 175 60 15's. fit a treat and can just stick a finger in the gap between tyre and arch.
Also, I can confirm this setup clears both early and late type rear arches - as our bus has one of each :shock:
ive tried 175 55s an they wont go.ive read that flat4 and ssp etc have different ets
BRMs with 195/60/15s fitted on the rear.
69PROJECT said:
Grazy said:
Steels Simon !!
boring,im also stubborn.... :oops:
Steels aren't boring....
Looks tight?
A friend of mine (Tintop on here) recently had trouble fitting his wheels on the back of his van because newer tyres seem to all have sidewall protectors (thread here: http://forum.earlybay.com/viewtopic.php?f=4&t=43658" onclick="window.open(this.href);return false;)
For what it's worth: steels all the way in my opinion :D
gvee said:
Looks tight?
A couple of mm between tyre and arch, but never rubbed.
