will raders/radars fit???
resto73
May 1, 2007
234
Redditch Worcestershire
Hi there, ive read contrasting views on this subject so the easiest thing is for me to ask the experts ;)
will jge/mws radars/raders fit my stock 70 bus rear axle? or will the wheel centre part foul on my axle nut or snout?
the front wont be a problem for me as its linkpin'd with late split drums so they'll go straight on
many thanks in advance, Paul
They were fitted to my bus when I first bought it, but I think the hub nut had been machined. The po had moaned about the fuss getting them to fit.
http://www.volkszone.com/VZi/showthread.php?t=326191&highlight=whitearmy61" onclick="window.open(this.href);return false;
Yes they do fit but require quite a bit of work.
I fitted a set to Windsurfers bus for him, we had to:
Use a 10mm spacer and bolt extensions
Change the castle nut for a T25 nut
Pull the rear arches by 2mm
And we still couldn't get the rear dust caps on!!!
But they look cool as on his bus so worth it in the end.
