It’s a early 71What year is the bus, the 70/71 onwards were much lighter.
I stained the parts I replaced to give them a coat of protection from the damp.i don't think there was any stain on the roof panels, just whatever varnish they used in the 70's tends to yellow with age.
That would be brilliantThat should be the much lighter wood. I did replace some wood in one and I think I kept the tin of stain for reference, let me look for it and ill try and let you know.
Yes but its 4mm and he wasnt sure it would fit in the standard trims without triming downHave you tried this chap? I bought a floor from him, superb quality and very quick delivery.
https://www.customshopdesigns.com/product-page/vw-baywindow-camper-van-3mm-birch-ply-roof
Sorry, I only had the stain I used on mine which is the darker/earlier type. I think I chucked the old tin when I moved. Lesson learned. … don’t throw ANYTHING awayThat would be brilliant
Do you have the ‘headbanger’ locker installed ? I think the ply headliner is supposed to hold itself up by flexing upwards when installed onto the two side rails.My rear panel sags. How can I hold it up in the middle? I don't think this panel is original.
Is there any way you can take the sag out El temprer with an upside down broom or similar to spread the load or even two or three to regain the original shape. Then investigate any play or slop or slack in the side / supporting rails then take up the slack physically with paired wedges in several places along the sides, obviously very small ones then fill the gap with one of the multitude of gap filling adhesives on the market. Might be even better if you can do it all on one side. There are adhesives available now that will expand slightly as they’re curing a bit like a tiny version of expanding foam. Gorilla glues do one and it is fab. When it’s cured you can easily remove excess with a Stanley blade.My rear panel sags. How can I hold it up in the middle? I don't think this panel is original.
