Hi All,
I thought I would put up a quick post as my ignition barrel has failed on my van!! The key, when in the ignition barrel, will rotate enough to release the steering lock (one click) (mine is a US spec van) but will rotate no further at all.
Does anyone know whether the lock barrel can actual be removed alone. I have undone the 4 large screws to pull the steering column away from the dash and underneath the black triangular casting the steering wheel is attached to I have undone the tiny screw that holds the bakelite switchgear at the rear of the ignition barrel in place, but is there anyway I can remove the actual ignition key part from this?? And if so can I get a new barrel? I have seen VW Heritage sell something that might be right but thought I would check.
Any help would be warmly appreciated.
Thanks,
James
Thanks,
James
