Been doing a bit of cleaning while the suns been out 8)
Then I added the result of a few winter nights in the garage with the dremel and two wooden nobs...(Madam...)
So I now have a matching Suicide nob, a gear shift nob and a Morph - Well actually Morph was made from a spare Stave of Walnut from my kitchen surface and the Gear nob / Suicide nob turned from African Zebrano which has a wonderful striped grain.
I also decided to contrast the front and rear wheels a little more by stretching the rear ones out a little. The front wheels sit on a Slammwerks narrow beam with T2D dropped spindles. I think the beam was between 3.5 and 4'' narrowed, so not too extreme. So to add to this I thought the rears would look a better contrast an inch wider and and inch closer to the wheel archs. I started with a couple of stock 14'' wide five's (thanks Slammed
) and sent them off to banded steels (http://www.bandedsteels.com/" onclick="window.open(this.href);return false
for a 1'' band to be added to the outer edge. You can't F&*ck around with banding wheels unless you are 100% sure that they will be done properly and these guy's (Kris) seem to know what they are doing and how best to do it safely (all laser cut, jig loaded and inner seem welded). Must admit I'm really happy with the result. Painted them the same as before and Ant did the business on the whitebanding (Tks for accommodating with such short a notice Ant
So the end result looks like this..
You don't notice it straight away, you have to second look and I kinda like that...
