ok, popped up the body shop this afternoon. all i can say is, this guy could make a living out of what he has done for the last 30 years
i bought an inspection hatch but the lid was plastic. Unfortunately it needed to be shrunk in size, but being plastic they cant cut and weld. so the guy at bodyhsop said that he could cut the hole carefully and use what he cuts as the lid. he has made a frame to fit underneath. this worked out well as the T25 hatch has a differnt corragated profile that is in the back of an earlybay:
he's put a rubber beading around the surround and will do the same for the lid itself once he's tidied the edges up:
so the middle panel is completely on and it looks amazing!!! cant believe how things line up. the doors line up the roof lines up and the wheel arches line up - inner and outer.
this is the only part that is welded form the outside:
all the rest is spotted from the inside so unseen:
the LHD rear floor came with an adaptor plate that you weld the the O/S floor section. they have spotted this to the bulkhead, the middle panel and also the sills:
front end is all finished with exception to sanding the spot welds down and sealing:
blanking plates as you can only get LATE BAY floors
they've also started on the rear corner. this is the picture of the corner they havent started:
and the other side
original battery tray hahah ye right
and the removable valance is being fitted tomorro too
i'm off up there again on friday to check progress. so what do you all think???
o ye, and dont tell loxy that this is his middle panel that i've fitted
