Haveacamper
- Joined
- Oct 2, 2007
- Messages
- 2,073
- Reaction score
- 5
cheers guys
the porsche engine i had was already installed in nelly's bus so in reality i didnt have that much extra work to get it running. the engine already had a wiring loom attached to it which meant all i "needed" to do was to connect the wires up. however, i completely rewired the bus so thought i would rewire the engine too. i hav eall of the porsche clocks running on the dash which meant that i could run all of the senders up from the engine with no worries. then i also ran made the vw light wiring from the dash switches etc.
as uber stated you need to fit the oil tank for the dry sump engine. most people fit it in replacement of the battery tray and then mount the battery tray on the platform tray on the other side. that may give you an issue with extending the battery wiring to the other side. for me, as i rewired the whole bus this wasnt an issue. if you have a leisure abttery on the platform tray you may need to move this to under the rear seat.
i also have an external oil cooler in addition to the engine oil cooler. this is mounted underneath the bus. this oil cooler has its own thermostat and a fan controlled off a seperate thermostat - again this will need wiring in.
if you are running the porsche engine, you may want to consider upgrading the engine. i have had my 6rib box upgraded with a taller 3rd and 4th gear. also, if you have considerable more power going to the wheels, you may want to consider upgrading the brakes to stop.
ok, so i got a good day on the bus on friday and managed to route the wiring under the bus and into the engine bay. i also managed to fit the headlights, the indicators and the rear lights. not just bolted in....also wired in for potentially the last time
also, i managed to fit the door rubbers to the cab, slider, tailgate and engine bay. must say...the cab door ones were very hard to shut the doors once fitted. i thought, if fitted them now i wouldnt be slamming the doors when it got around to actually using it properly lol
thanks again for the comments guys...your comments are much appreciated and its getting really exciting now i'm coming to the last hurdles
next thing is to mount the engine relays and fuses in the engine bay
