1600
009
Recent top end rebuild.
At idle: removing HT lead from dizzy for cylinder 1,2,4. causes lumpy running as you would expect.
Removing HT for cylinder 3 makes not a blind bit of difference to engine noise.
Compression test came back good, changed spark plug 3 times, and swapped HT lead. Checked points gap, timing and replaced dizzy cap.
At HIgher Revs: If you increase the revs by a few hundred RPM removing HT lead 3 has the effect you would expect, noticable difference in engine noise and lumpy running.
What gives? I've asked a few people, one person suggested that this isn't unusual. He says dubs often run at 3 1/2 cylinders intil revved a bit when the full 4 kick in, but this sounds a bit odd to me. Any ideas?
How it drives: On a run, up hill and down dale, the bus runs great, I've been to Arran and back and all over the uK this summer and it has run nicely through out. Pulls well and doesn't feel underpowered even with a full load up hill. The only slight flat spot is when initially pulling away. You have to give it a bit more revs than feels quite right or it can sometimes stall.
Cheers,
Pete
009
Cheers,
Pete
