3 point belts in a early bay
Whit
Jun 20, 2011
196
Cotswolds
I want to fit 3 point belts in the back of my bay is there a easy way of doing this?
Yeah the anchor points should already be there covered by black plastic screws and Screw holes under rear seats.
Lap belts are fitted at the moment I don't think mine has the hole in the pillar or did all bays have them ?
All kombis and microbuses had them. Panel vans didn't. There should be one in the metal work below the rear side window and also in the metal work between the side windows.
Hi,
I've put these ones on my to buy list to do the same as you;
http://www.justkampers.com/211-857-693-c-rear-3-point-seatbelt-with-extender-for-t2-1950-1979.html" onclick="window.open(this.href);return false;
Get them and let me know if there anygood!
These holes?
Whit said:
Any other seat belt options ?
Sent from my KFTT using Tapatalk 2
I've got a 72 converted panel so had to get small plates welded into the rear to anchor the belts onto, only took a couple of hours, only issue was finding a set of longer belts that reached from the back section.
I'll try and dig some photos out later today?
what make of belts did you use?
try putting Securon into ebay, then find KCP Commercials in Bury st Edmonds 01284750777.
I just fitted 2 x 3points (Sec 500 W) and 2 lap belts (Sec 210) for 98 quid. the chap was really helpful
good luck
hiya on my microbus did this for mine so they didnt interfere with origional bench seat or spare wheel cover.
shouldnt go anywhere as its 10mm thick plate with a stop welded to it to prevent it moving if any thing happened.
cheers Pete
