aogrady
Bough a while ago this 4 burner hob and grill, comes with all burner caps and alloy burners and pan supports all in very good condition, bar a couple chips of enamel shown in the picture. You can get enamel paint from toy shops, remember your Airfix kits?
It has electric ignition, but i don't have the spark box, a battery powered one is available on ebay if you wanted, nothing wrong with a match or lighter, i have left the igniter leads in place in case you want this activated.
Also have the metal work the hob has underneath when it was fitted in a caravan, and the metal cover for behind the grill door. You may not need the metalwork, but you could fabricate something with this if you really wanted to, also included are some piano hinges for the door, and the surround seal the hob sits into.
Will happily post at cost, maybe around £8 due to weight.
I am in Instow, North Devon
Cheers,
Alistair
Cheers,
Alistair
