markevo30
72crewdude,
Glad you like the bus
. I'm pretty happy with the way the bus sits too, it's about as low as you can go without notching/tubbing and retaining a half decent ride. I have mimimal rubbing/bottoming out issues with this setup.
The front has a 4" narrowed Slamwerks king and link pin beam with the adjusters on their highest setting and flipped spindles with short shocks. The wheels are 5.5 x 15 with 165/50R15 Bridgestones.
The rear has been lowered two outer splines (i think), has shorter shocks and runs 185/55R15 tyres. I'll probably fit some adjustable spring plates at some point so i can raise her up a bit when fully loaded for camping. These would be fitted with just a one spline rotation as there's not a lot of travel before the spring plate hits the top of the housing at the mo.
Mark
Mark
