Hi,
I've just bought a 71 bay from Nevada, it's dry as a bone shell wise, but appears to be lacking in the mechanicals department.
I've just tried to fit a new clutch cable, but unfortunately I've not been able to do this as the metal tube / conduit that the cable runs in is bent & kinked so the old cable whilst still working (just) can't be adjusted because I can't pull the wing nut adjuster away from the clutch arm. It needs a new tube!
I've looked on line, but I can't find any replacement tube parts other than the flex conduit.
Has anybody else had this problem and what did you do to fix it?
