mychatype3 said:Hello all,
I’m also running airshocks in front. Already 15.000km on them![]()
What i have:
narrowed beam 5,5cm taller (2,75 a side)
dropped spindels
adjusters in both tubes, and lowered only on the upper tube
6mm air lines
Monroe Ma824 (first i had the ma803 but they didn’t lift more then 3cm)
When 20psi is in 58cm (tires 165/65/15)
When 140psi is on 62,5cm (150psi 63cm)
Old video with higher tires 175/65/15 and the ma803 shock’s
Greetings Mycha
Mycha, can you confirm thats the 803 with the beam off the bus and the 824 in the picture with them on the bus? I worry that if the 824 has the bag that inflats outside of the shock without a cover that it will rub against the bolt that mounts the beam to the body and to the spindles.
