Ok I have tried a few belts now. The Optibelt 11.3x 912 I had used for a fair while was looking a bit old and had one shim between the generator pulley wheel. I made a mistake in my earlier post. I said this was a new pulley wheel is in fact the one I got when I had the alternator conversion done, so came with the Bosch alternator conversion kit. It still looks new though which is why I got confused.
The crank pulley is a new billet aluminium CSP one that CSP recommend using a belt 11.3x 912.
The SPA 12.7mm belts I tried are too wide for the crank pulley.
I went on a short test drive after fitting both the 900 and the 907 which both fitted with 8 shims but I found that when back home there was black particles all over the engine bay. I surmised this was the crank pulley shredding the outer edge of the belts. The gap at the top of the crank pulley wheel is 11.5mm approx.
The SPA 907 belt after a 5 mile test.
I then tried another belt I had lying around. This is a new 11.3x912 belt
This fitted with one shim which ideally is not enough for a new belt, and I am not a big fan of the toothed belts. So I ended up back at the Optibelt 11.3x912 which I got from machine7
[emoji23]
Fitted this new belt which measures correctly width wise, and I have 6 shims so I’m a happy amateur mechanic. [emoji106][emoji3]
[emoji23]
