7.5 btdc is idle timing at stock idle rpm. by all means check the timing at idle but you send svda at full advance. ie over 3000 rpm with the vac line blocked.
should be set to about 28-30. i'd personally try 30 take it for a blast some hills if it pinks.. drop it by 1
