Doris
OK guys,not being manufactured by anyone else,I had these made up for a repair on my bus as I know the only way to get rid of rust is to cut it out and replace with fresh metal. But nobody makes this piece......until now !! Then my mate wanted some, then the garage wanted some etc etc.So I had a run of these made as there is bound to be others with rot in this area with owners not wanting to botch up with filler.you cannot get this piece new or even as a flimsy repo.
Manufactured from correct grade 1mm thick mild steel,so should weld in nicely to existing bodywork.I've left a wide margin around the repair area so you can trim back as much or as little as you need.They are taken from an original Hannover metal VW template and laser cut, so the fit is perfect. I have 20 items on hand ready to post so if you want to get in, copy and paste your name in the usual fashion and I'll pm you with details.
price is £10 each + £3 'signed for delivery' for a pair, bit cheaper for just a single piece.
this pic to show the perfect fit....
