faux
Just found out that the oil cooler had split, he had never seen that before.
Should be up and running by the weekend.
Few!!
Few!!
faux said:Just found out that the oil cooler had split, he had never seen that before.
Few!!
Trikky2 said:if you havnt already, use 15/40 multigrade. Its thinner than straight (prehistoric) 30 when cold.
Pete B said:Jon, same as everyone else, hope you caught it in time and it's an easy fix. Hope to see you at VoWo.
Trikky, can I use this quote next time the 'what oil should I use' question arises!!??
Edit; posted this before seeing the cause had been found. Damn good news. 8)
Few!!
Trikky2 said:faux said:Just found out that the oil cooler had split, he had never seen that before.
Few!!
Good news - still worth checking the relief valves are not sticking though, unless your sure the oil cooler was a duff one.
As if my wife would clean the drive.....we get loads of rain in Wales, it will wash off eventually.Merlydog said:I'm more concerned for your mrs, that's gonna be a bitch to get off the drive!
*Sam* said:I'm told that coke a cola will clean the pill of the drive way and the cheese the better apparently, I have never tried this method .
sparkywig said:*Sam* said:I'm told that coke a cola will clean the pill of the drive way and the cheese the better apparently, I have never tried this method .
OK Sam, put down that glass now....
