GreyPrimer72
- Joined
- May 8, 2008
- Messages
- 16
- Reaction score
- 0
Hello All,
I am having a few problems with my battery not charging very well. I have checked the fan belt and it has the correct tension. If I take the battery out, and charge it with a charger, it will work for a about 15 starts before it is drained again. I think the battery is ok (the charger I am using has a built in tester that says it is ok)
I have measured the voltage from the across the 2 terminals on the Dynamo and am getting about 5 volts while the engine is running. (Shouldn’t this be 12v?)
Could anybody give me any tips or tests to diagnose the problem?
Graham
Graham
