Ok guys I need some help here.
for those of you who are about to help and would like to see my van follow the link below.
viewtopic.php?f=8&t=59380
My camper, who I've decide to name Laura, is nearing the final stages of "getting her done". All that remains is the wiring problem which I'm going to rewire the whole bus, the Brakes, but then there is the Engine.
I am going to be keeping her as much stock to look at but I would like the engine to have a bit of poke.
I will be putting an Eagle Cam in her as I know this does improve performance but I am wondering if there is anything else I can do.
The engine she has in her has a H code on the block which i have found out to be 1500cc and it's single port.
I have bought an engine block with the heads on for a twin port, I was told this is a 1600cc
Seeing as the original engine sat 24 years I was going to strip and rebuild her. We got her running whilst in the states but I couldn't remove one of the spark plugs. She did run, but as you can imagine after not being started for so long she was running rough.
So the question is what modifications can be made or added apart from the cam and what should I use as an engine block.
I read in another thread that you can turn a 1500 into a 1600 maybe even a 1641 without boring out the head, is that true ?
I am no mechanic but I have stripped and rebuilt an engine in college a few years back and bought the " how to rebuild a vw engine " dvd of ebay and watched it a few times.
I have made a bet with my friends that I'll have her running and on the road by May 1st.
Jason
Jason
