Doris
right guys I need your opinions.....OK, I bought a radio that was sold as Bay window. its one of the old sapphire ones (although the VOLKSWAGEN script has worn away now). The embossed 'leather' pattern matches the pattern on the dash pod,top and glove box perfectly so I'd like to fit it.
however the dash is original,un cut in its OG paint as is the hole for the radio.
The dilema...
The actual radio unit fits in but the plastic patterned surround that finishes it off has a recess that is too big for the OG hole. so if I want to leave my dash un touched, the surround sits proud by about 1/2 inch and looks daft. If I want it to sit right , I have to cut my dash hole bigger - what do I do??.
my thoughts...
If I were fitting a modern flashy head unit it would be NO, NEVER cut the dash, but I'm leaning toward cut and fit because a) its an original VW radio I'm using & it matches the rest of the dash b) its just what I want there. c) you won't see that its been cut when fitted d)the bus has had welding work & resto that has made it unoriginal anyway & interior will be re done so just do what you want and enjoy it.
BUT....
should you always leave something original (as it is as once its enlarged you can never go back?)
please vote above!!! cheers - Rob
The dilema...
my thoughts...
BUT....
