Big motors, who's packing what?
K@rlos!! FK 10 and those heads :O
Should have some nice pickup.
My single cab has
• Case: Type I, Auto Linea, 2165cc : 78 x 94
• Heads : CB cnc round port, 40 x 35.5mm s/s valves, performance multi angle valve job, chambers reworked, un-shrouded valves & polished. Stock 1.1:1 rockers, Shimmed HD shafts, Porsche style swivel foot adjusters
• Crankshaft: Scat forged chromoly c/w 78mm, endfloat set to: .027”
• Connecting Rods: Scat I beam ARP 3/8 bolts
• Camshaft : Engle W110, endfloat set to: .002”
• Camshaft manufacturers recommended valve lash : Intake .002”, Exhaust .002”
• Straight cut timing gears with .003” gear lash
• Cylinder spacer fitted: 1.5mm
• Head gasket fitted: .060”
• Combustion chamber volume: 60cc
• Deck height: .060”
• Static compression ratio : 8.6:1
• Carbs: Dellorto 45 DRLA
• Distributor : MSD Billet with MSD 6A control box
• Ignition : 32* total advance
• Spark plugs: NGK D6EA
• Clutch: KEP 200mm Stage 1, 1700 lb, dual compound solid disc
• Flywheel: 200mm lightened 12lb, 12V
• Exhaust System: Vintage Speed superflow muffler
• Oil system: 26mm blueprinted pump, full flow with filter, cooler and thermostatically controlled fan, deep sump and case modified for improved windage and oil return
• Engine assembly balanced and crank oil clearances set to .0025” - .003”
• Vented tappet covers and oil filler/CSP breather box
• Engine oil: Brad Penn
. 98.7HP at the wheels
HI Daisybay
I have upgraded the brakes to later bay discs and drums. Stopping power is excellent.
The gearbox in mine is an 1800 box with 1600 fourth gear to give it a little bit more legs.
The suspension is in very good condition and I have added Koni shocks up front. Mine is lowered all round.
It feels comfortable at 130km/h
madmike said:
If you Guys take it easy on the throttle :lol:
What kind of 'Mileage' you getting? I'm thinking about another 'stroker' build 8)
After 3 years and just over 12k miles I can get low 30's mpg on a long run sitting at 65-70 mph.
If I drive it like it wasn't intended it drops to about 10-12 mpg.
My single cab has
Nice in depth post mate, Intresting 8) Yes hopefully it should be a serious grin maker. Mines running a much tighter deck, 30 thou I think and a compression of 10:1.
I bet your combo in a light single cab is fantastic to drive.
Daisybay said:
So you have a big engine in an old Bus. What upgrades have you done to the running gear? My Bus is a handful at 100KM/h (60MPH)
I'm still running stick drum brakes :shock: I know.... but reaslically I only do 65-70mph on trips as it's pretty economical and any faster you start to go deaf :lol: As for gearbox I've got a 'built' 002 from the Cogbox. Taller ring & pinion, stock ratio gears which are welded, with all reinforced internals and a super diff. Also run chromoly 'race' drive shafts.
Also lowered with a 6" narrowed king & link pin beam, dropped spindles, adjustable spring plates, tubs and notches etc
Case: AS41 69*94 VW do Brazil MAG case, full flowed, Bob hoover HVX mods, Rocky Jennings grooved Silicon Bronze lifter bushings, #3 main journal modified for dual center main bearings.
Gaskets & sealing compounds: Victor Reinz gaskets set, Elring silicon main seal, Elring Curil T sealing compound between cases halves, cylinders seated with Momentive RTV 106 silicone paste, all is torqued with ARP lube.
Crankshaft: 4340 chromoly 78mm Flat4 crank, steel backed Kolbenschmidt main bearings, 36mm AA performance forged chromoly gland nut.
Flywheel: 200mm chrome vanadium forged VW, stock weight, balanced with crank / damper pulley / clutch disc / clutch pressure plate / cam & distributor gears separately and together.
Clutch: Kennedy stage 1 pressure plate, Sachs throw out bearing, ACE Copperhead super disc.
Rods : DRD 5.4" I beam, VW journals, ARP 3/8" 8740 bolts, balanced end to end, Clevite77 bearings.
Pistons & liners : AA Performance 94mm « B » pistons and cylinders, polished pistons tops, Berg clips, CB performance #1213 lightweight tool steel wrist pins, modified to fit AA slipper skirt pistons. Thermal barrier ceramic coated pistons tops.
Displacement: 2165 cm3.
Camshaft: Engle FK44, Magnum straight cut gears.
Lifters: 28mm 56g Torsten Pieper tool steel lifters.
Pushrods: Smith Brother 2024 aluminum alloy ordered to length, Ray Vallero “oil squirters” modified, Jaycee pushrods tubes.
Rockers: CB 1.4:1 (1.48 real ratio)
Cylinder heads: Steve Tims Stage 2 heads, without standard hardware.
Valves: CB Racemaster +.250 inch length 42 mm intake (#1372), 38 mm exhaust (#1370), 2 angles, matched to valve seats.
Valve springs: Single Comp-Cams #26125 BEEHIVE springs.
Retainers: Comp-Cams #762 Titanium retainers.
Valve locks: Comp-Cams #628 chromoly valve locks.
Lash caps: Comp-Cams #619.
Valve covers: Scat stainless steel, oil drain from #3 & #4 cylinder head to oil sump.
Manifolds: Bugpack #1038 straight manifolds, match ported by Greg Tims.
Static Compression ratio: 9.6 to 1, 0.04" deck height, 56cc chambers. Thermal ceramic coating in chambers, exhaust valves & ports.
Oiling : Blue printed “Berg like” 30mm Brosol oil pump, Berg GB239B bypass oil pump cover, K&N HP3001 oil filter, Racimex oil thermostat, 8 pass Scat additional oil cooler, stock “dog house” oil cooler with hoover bit, Scat sump, Jaycee billet drain plate.
Cooling : Scat « dog house » round shroud, TIG welded and balanced VW OEM fan, open welded thermostat vanes, all tins in, industrial tins between header and heads.
Exhaust: A1 1" 5/8 stainless steel sidewinder header with O² bung, A1 2" ½ stainless steel Magnaflow muffler.
Ignition: Pertronix billet distributor with ignitor 2 ignition module, Pertronix Flame Thrower 2 coil, 8mm silicon CB performance wires, Pertronix Second Strike ignition box, NGK DCPR7EIX iridium spark plugs.
Carburation : 2 48 DRLA Dellorto carburetors, 38 mm venturies, CB Dellorto #7348 Jets Doctors sets, 215 Air jets,165 Main jets,63 Idle jets,50 Pump jets, Facet Gold-Flo #480532E fuel pump, King fuel pressure regulator, home made cables linkage.
I do like how you have used the firewall to mount some of the fuel system - very clever!!
Davydomes said:
Is that with a Servo fitted? I only ask as we have done the same with no servo. We have fitted the pressure regulator to stop the rear wheels locking.
Hi.
I have not got a servo (booster) fitted.
No issues with locking at all.
[youtube]9-DERgR4rXQ[/youtube]
2165cc CB Performance EFI : 160HP
Richard Sterling built European Motorworks assembled motor.
Jake Raby Type1 DTM shroud,
CB Performance Magnaspark ignition
CB Performance Quicktune EFI kit
BDM Serpentine Pulley system
Eagle 110 cam,
CB Performance Crank and Deep sump,
Match Ported and polished CB Performance Magnum 044 heads,
AS41 Dual Relief Super Case, Full Flowed
Super Race Rods
Maxi 30 Full Flow Oil Pump
CB High Performance Case Kit
28mm Ultralight Lifters
Straight Cut Cam Gears - matched set, crank & cam gear
Chromoly Push Rods
Super Big Bore Kit 94x82mm
C Channel Valve Covers
Forged Chromoly Lightweight Flywheel
CB Super Stock Rocker Arms
I've still not driven mine as the restoration has got very in depth :roll:
Had a bit of a spend/re think regarding running gear....
Gonna be running Porsche 944 turbo discs & calipers up front, CSP early bay rear drums with Porsche 5x130 PCD, Porsche gasburner rims and to top it all off an 091 6 rib gearbox which will be rebuilt with a few nice goodies.
Bloody hope so :lol: Might splash out on some Weber 48 IDA's next year
Not exactly big, but refined - 1835 singleport, engle 100, DPR crank, AA pistons, 1.25 intake rockers, single HD springs, stainless valves, porsche piston squirter mod, bob hoover oil channels mod, heavy 8 dowel flywheel, precise balanced, cb ultralight lifters (sweep the floor stuff), o ringed pump, machined rear pulley seal, ahnendorp exhaust, full cooling tin with industrial lower tins, thermostat and velocity ring, scat sump with CSP long oil suction basket.
2276cc, FK-8, CB Los Panchitos 043 heads, A1 merged system etc etc, 120RWHP, goes well :)
I said I might and I have.... :mrgreen:
Brand new, only been run once and come with a CSP linkage. Red stacks are making way for some polished versions
Got the tinware re painted and finally got the 48 ida’s and scat-trac manifolds on :mrgreen: Just need to fit the new ceramic coated header and muffler
Replaced the 1600 twin port unit running 34ict’s electronic ignition and a VS exhaust with this:
After a bit of cleaning and stripping had this
Now installed in the bus
2001 Subaru Legacy EJ25 (2.5ltr) Flat Four Boxer engine, fuel injection, Bosch 044 Fuel Pump, Cold Air Induction, Powersteering and Aircon delete, shortened sump, performance leads, plugs and coil pack. Braided fuel lines Custom exhaust made by Mike Hausmann.
Power should be approx 180/190bhp
