- Joined
- Apr 22, 2012
- Messages
- 2,220
- Reaction score
- 207
- Location
- Dorset
- Year of Your Van(s)
- 1971
- Van Type
- Dormobile
Great job very similar to my engine but I put a 123 distributor in mine. Do you think the MSD Billet with MSD 6A control box is a better option? Also dose the deep sump help? Also how do you get on with that clutch in I bullsed up a bit by just putting a lux in I think it dose slip a bit.K@rlos!! FK 10 and those heads :O
Should have some nice pickup.
My single cab has
ā¢ Case: Type I, Auto Linea, 2165cc : 78 x 94
ā¢ Heads : CB cnc round port, 40 x 35.5mm s/s valves, performance multi angle valve job, chambers reworked, un-shrouded valves & polished. Stock 1.1:1 rockers, Shimmed HD shafts, Porsche style swivel foot adjusters
ā¢ Crankshaft: Scat forged chromoly c/w 78mm, endfloat set to: .027ā
ā¢ Connecting Rods: Scat I beam ARP 3/8 bolts
ā¢ Camshaft : Engle W110, endfloat set to: .002ā
ā¢ Camshaft manufacturers recommended valve lash : Intake .002ā, Exhaust .002ā
ā¢ Straight cut timing gears with .003ā gear lash
ā¢ Cylinder spacer fitted: 1.5mm
ā¢ Head gasket fitted: .060ā
ā¢ Combustion chamber volume: 60cc
ā¢ Deck height: .060ā
ā¢ Static compression ratio : 8.6:1
ā¢ Carbs: Dellorto 45 DRLA
ā¢ Distributor : MSD Billet with MSD 6A control box
ā¢ Ignition : 32* total advance
ā¢ Spark plugs: NGK D6EA
ā¢ Clutch: KEP 200mm Stage 1, 1700 lb, dual compound solid disc
ā¢ Flywheel: 200mm lightened 12lb, 12V
ā¢ Exhaust System: Vintage Speed superflow muffler
ā¢ Oil system: 26mm blueprinted pump, full flow with filter, cooler and thermostatically controlled fan, deep sump and case modified for improved windage and oil return
ā¢ Engine assembly balanced and crank oil clearances set to .0025ā - .003ā
ā¢ Vented tappet covers and oil filler/CSP breather box
ā¢ Engine oil: Brad Penn
. 98.7HP at the wheels
For a mild street engine a stage 1 pressure plate and dalken disc is all you need. Donāt worry about an MSD the 123 is perfect for what you have. And as for a deep sump they DONāT result in a cooler engine, if your engine is running hot and everything is all ok you need an external oil coolerGreat job very similar to my engine but I put a 123 distributor in mine. Do you think the MSD Billet with MSD 6A control box is a better option? Also dose the deep sump help? Also how do you get on with that clutch in I bullsed up a bit by just putting a lux in I think it dose slip a bit.
Oh great thanks for the info. Luckily enough it doesnāt seem to run hot at all but still thinking of putting an external oilFor a mild street engine a stage 1 pressure plate and dalken disc is all you need. Donāt worry about an MSD the 123 is perfect for what you have. And as for a deep sump they DONāT result in a cooler engine, if your engine is running hot and everything is all ok you need an external oil cooler
Have you got an oil temp gauge? Have you done any long trips on a hot day yet?Oh great thanks for the info. Luckily enough it doesnāt seem to run hot at all but still thinking of putting an external oil
Cooler on. Iāve ordered the clutch and plate you suggested
Yeah I have a oil gauge I drove down to Cornwall from Shropshire last July, think the hottest it got was 110 on a long hill on the motor way.Have you got an oil temp gauge? Have you done any long trips on a hot day yet?
110c I assume? That definitely needs an oil cooler then! Wants to between 80-90c. Donāt forget to use a thermostatic sandwich plate on filter housing when you do.Yeah I have a oil gauge I drove down to Cornwall from Shropshire last July, think the hottest it got was 110 on a long hill on the motor way.
I will put a oil cooler on but wanted to wait until I could have the time to do it probably as I do long trips to Spain even Italy.
To be honest I donāt really drive it hard say 65 mph tops usually happy to cruise at 55 , the main reason for the 2010 was easier to drive in todayās traffic and to get up hills.
Sorry I donāt agree you should never run a aircooled engine too cool. 80c would definitely be too cool. 90 to 100c is ok and if itās hot up a long hill 110 is totally fine.110c I assume? That definitely needs an oil cooler then! Wants to between 80-90c. Donāt forget to use a thermostatic sandwich plate on filter housing when you do.
I saw 120 on the way down to Cornwall from Gloucester last year on the hottest day, driving at 60. I was quite worried, but only because I'd fitted a temp gauge!! I have an oil cooler, but it wasn't working, I've now hopefully fixed it so looking forward to testing it. Instructions say the fan comes on at 85C.Yeah I have a oil gauge I drove down to Cornwall from Shropshire last July, think the hottest it got was 110 on a long hill on the motor way.
Yeah 120c is worrying but slow down to 50 and if it goes down every thing is working ok. Iām sure people have different ideas but I think 100c ish is a good temperatureI saw 120 on the way down to Cornwall from Gloucester last year on the hottest day, driving at 60. I was quite worried, but only because I'd fitted a temp gauge!! I have an oil cooler, but it wasn't working, I've now hopefully fixed it so looking forward to testing it. Instructions say the fan comes on at 85C.
