dubscum
my brake lights have stopped working, striped all the rear light down cleaned then, light sanding of all the connection and a tad of copper grease and put it back together, shouted the wife out to stand on the brake pedal, nothing. jacked it up took the connection off the master cylinder and cleaned them up. Nothing. I checked and there is no power at the rear. (granted i didn't check power at the master cylinder) all the fuses are in tack. So i'm thinking its the pressure switch (or what ever its called) in the master cylinder. Can i change this without having to bleed the brakes ?
