Still going..... a while since the last update as other things have been getting in the way of bus progress... one sick Alfa who's radiator decided it would finally give up the ghost a few days before the MOT was due. Fortunately I had one knocking around the barn in anticipation. So Bunty had some company for a while:
Took the opportunity to whip the head off and sort out a small oil leak that had been niggling me for a while:
So with the Alfa back together and through his MOT with flying colours, it's back to the Bus...
Chopped out the rot in the front chassis leg, and grafted in a new section:
New bracing plate welded in, and the leading edge of the chassis leg replaced with fresh metal:
Got the B-post finisher in to give me a datum for the main B-post:
Made up the lower B-post and welded that in (not proud of my welding here - I was having a bad day I think! This will be tidied up later!):
Then turned my attention to 'the bulge' in the bulkhead, and shaped up what amounted to something akin to half a boob.... not sure quite what size... about a 34B I guess... but it helped me judge whether the shape was developing along the right lines! Again - the welding's not pretty, but should tidy up OK.
Not sure what happened to the wheel arch, but it's completely the wrong profile for the door line, so I started doctoring it in the hope I could reshape it enough. I've got a new outer repair panel which has the correct profile, so out came the corresponding part of the old one:
Had to get the bottom of the A-post rebuilt to give me a chance of getting the arch back in. A certain amount of guesswork here as there wasn't much left of the original... and what was there had been butchered by someone before me:
Despite attempting to wrestle and beat the arch into submission, there was no way it was going to fit properly. Nothing for it but to chop it in half and fit it in sections. Lined up the forward section, and tacked it in place:
It will need some work around the point that it turns the upward curve, but I reckon this is the only way I'm going to get it to give me uniform door gaps.
Seat pan is also tacked in to give me the line for the other half of the wheel arch. Another poorly shaped panel as this has a different inboard curve, so I've had to slice it open and it will need a patch grafting in:
That's pretty much it for now, but I'm looking forward to getting this corner finished and working my way round to the other side.
Got a few other projects that are on the cards soon though - MX5 needs to be serviced and MOT'd ready for the summer, and I'm hoping to get the TR6 body panels prepped up for spraying as soon as summer arrives.... Too many projects, too little time :roll:
