Cab roof lining
thejinx
Mar 30, 2011
1,522
33
swansea
Going to try and fit the roof lining in the cab once veh is out of body shop at end of month. Windscreen is out so that helps. My question is can I use any bars to get the tension and if not where is the best place to buy them and the clips to go with them. Also is this an easy job. Reading other threads some say yes others no. Also what glue will I need. Cheers in advance
You need the proper roof lining bars, they are shaped and different sizes,and also the small rubber ends on the bars, glue front edge where screen is ,at the sides there is a grip above the door which can be purchased if one is not fitted from factory that the headlining pushes into
