jacks906
hi all
i'm trying to get hold of, without any luck, some cam shaft double thrust bearing, but everyone i've tryed so far are out of stock and aren't expecting any in for a while.
someone (from hertiage or just kampers cant remember) said people are buying two sets of standard bearings and and using the thusty bit so you get you double thrust bearings.
now, how do they do that and is it possible or advisable to do it or should i just use standard cam bearings as that's what VW intended??
cheers
dave
cheers
dave
