BamberJim
Never simple is it...!! right here goes, when you touch the breaks the bus makes a sudden dive to the right (LHD Bus) but then brakes true and straight (no pulling either side), have had the brakes checked on MOT rollers and have been advised that they are above mot standard and equal breaking?
bus is lowered and narrowed and is a 71 (disc brakes). has anyone else experienced this? any advice would be glady recieved as i and the mechanic are stuck on what is causing this. One of the shocks was loose on the top bolt, but have tightened it up and still have the same problem. i think it is something to do with the weight transfering to the front when you brake, but can,t seem to work out what it is
