Hi all,
I have had my motor rebuilt last year and had mahle 1641 barrels and pistons fitted and twin 34 weber ICT carbs. It runs fine but has always leaked oil the cause of which has now been identified as an over pressurised crankcase despite it having a bugpack breather kit and vented rocker covers. it had a billet oil filler neck on but that was changed to a standard filler and the filter changed on the breather and that made a big improvement to the oil leak. I was told to maybe fit a tower breather on such as the CB performance one. Before doing this, it was recommended that a compression test and leak off test should be carried out. We found compression at between 98 and 102 PSI on all four cylinders but when we did the leak off test, there was very little leakage and the pressure was holding.
Does anyone have any idea as to what could be causing the lack of compression as I'd expect to see better values than that having had a rebuild and done less than a couple of thousand miles.
Any advice would be appreciated.
Cheers all
Cheers all
