Csp disc brake conversion wider than drums?
Nicemini
New member
Mar 29, 2013
2
Can anyone tell me if the csp disc brake conversion is the same width as standard drums?
The assembly of the CSP Products disc brake system changes the track of your Bus on the front axle. You can find the precise value in the following chart:
Year Of Manufacture Track Variation per side compared to
’68 - ’70. -3,5 mm drum brake. ’68 - ’70
If you search for csp wide 5 disc .pdf then you will find this info in the general csp catalogue on page 17
That’s really helpful cheers! Slightly narrower is surprising but good! Il have a look for that now!
