cunning plan said:So I am currently on a self-imposed spending freeze, which is making work on the bus even slower than it was before. I am only fitting parts that I already have 'in stock' or other tasks that just require time rather than new parts.
I have had these hinge covers on the shelf for a while, which to be honest, I am not totally keen on, however, they are better than the metal hinge of the boot hatch and cover the necessary headlining cuts.
The other side for comparison - Open.
The other side for comparison - Closed.
Half-closed.
Clear and closed.
The screws I am using are nice stainless ones, but I did not like the contrast between the headlining material, the plastic of the cover and the screws. So I found a number-plate cap-screw-cover and tried it on one of the screws, which I think looks better.
I only had one cap though, so I will have to get some more :lol:
I will probably also try to put some more material into the gaps to make it look more integrated. Alternativly, another option would be to cover the hinge covers in the same material as the headlining.. Hmm, I might have a go :rocknroll:
___
[92%] Fit Headlining extra material around windows (Need to tidy / Hinge covers / Cover joins)
[0%] Wiring Loom diagram (This was 10%, but now back to 0% for a change in direction.
[0%] Wiring Loom component purchase
[0%] Wiring Loom fabricate
[0%] Paint rear drums
[0%] Fit rear drums
[0%] Plan and purchase complete Hydraulic braking system
[0%] Fit Complete Hydraulic braking system
[0%] Fit Accelerator Cable
[0%] Rear Windows Tints
[0%] Rear Windows Install
[0%] Revise Front Axle / Brake Drums / Track-Rods / Re Torque all
Buss69 said:Looking ace bud, if you don't like the colour of those covers try using Plastikote paints.
cunning plan said:Buss69 said:Looking ace bud, if you don't like the colour of those covers try using Plastikote paints.
I didn't think of the plastic paints, but that would have been another good alternative solution.
I went ahead and covered them with some spare headlining material.
It took me a few goes as it was difficult to stretch and press the material down to prevent ruffles, air-bubbles and ridges, especially on the corners where you have to stretch the material in different directions due to the convex and concave shapes. For such small pieces, they were quite 'technical' to do.
I mock fitted both covers before covering them and I am a little disappointed in the quality of the covers considering how much they cost (£45/50 IIRC). The right-side one was pretty good, but as you can see above, the left was not moulded correctly where it is skewed out of position, meaning that the holes do not line up correctly.
- A fork. Useful tool.
Right-side complete.
Left-side complete.
Both sides installed.
I used black number-plate screw-caps to tidy the screws.
I think that looks much better than the dodgy white plastic covers. They looked a bit 'cheap'. :|
____
[100% Complete] Fit Headlining extra material around windows (Need to tidy / Hinge covers / Cover joins)
[0%] Fit rear drums
Buss69 said:The underside looks amazing and the rear suspension and brakes look mint. Have to say you doing yours has motivated me to do mine. So is your underside undersea or POR15?
Buss69 said:As far as your loom goes have you contacted Autosparks or maybe even Watsons Street Works in the US? I'm pretty sure Autosparks have a range of add ons for extras on their looms. Worth a chat anyway.
gas1man said:All going according to plan then................ :lol: :lol: :lol:
Keep up the good work.
J & P
monkeyvanwestybike said:Nice work there!
I wish I had a double Garage![]()
gas1man said:Managed to find time for the bus??????????? :lol:
