aspira
I'm putting on a new dizzy as part of my re-build. It's an SVDA and should be setup at 7.5% BTDC at 900 RPM with the vacuum pipe blocked.
I just wondered, as I read through my old Haynes, they talk about different engines that have different ignition timing setting as per their engine numbers; So, AE numbers at 5 degrees ATDC and AD numbers at 7.5 degrees BTDC for example.
Is that simply because they assume different engine numbers run different dizzys?
