Wishart
Cant say Ive seen too many of these - not sure if they were even a standard issue by Dormobile? But basically its a waste paper bin that fastens to the inside of one of you cupboards using the standard twist/lock fixing used throughout the Dormobile conversion. Its been made out of the red/white candy stripe PVC used for Dormobile poptops so would suit any bus with the same colours. Or its just a nice little hide-away bin that uses virtually no space when not in use
Sizes are roughly 300mm top to bottom x 180mm left to right x 2mm depth when closed or 200mm when full.
£20 posted
£20 posted
