Plan to lay the van up shortly before the first road salt is laid.
In the past i used to run the engine atleast once a fortnight to keep everything ticking over,but,my question is,is this good or bad for the engine?
Am i just building up moisture in the engine and xhorst to which eventually the xhorst will rot and also potentially damage the engine because i don't drive it for any long distance's
So my question is should or can you drain the carb so as the fuel will not evaporate leaving sludge or grime in the carb body?
Running a 34 pict 3 standard set up.
Regards.
Sharky.
Regards.
Sharky.
