gvee said:For twins: I believe (but don't know for certain) that it is better for the servo vacuum to come off both inlet manifolds to get a more even balancing between the carbs.
Just tap into #3 intake. As soon as the engine starts it draws a vacuum and the flow stops. When you hit the brakes a small amount of flow happens but soon stops. It won't affect the engine. No need to tap all four because it's not a constant drain of vacuum. Do it like this:
