smudge
just removed from my just mot'd bus to make way for a slammed beam.
Beam,spindles,backing plates,drums and tie rods..missing is the steering damper,draglink and pitman arm.
The beam has been lowered but not welded with adjusters.It lowers with the wieght of the bus then returns back to stock hieght when jacked up so would either require adjusters or welded into a fixed position..IMO...
Also the top leaves have been removed for a bar so would reccomend replacing with your leaves...
The ball joints went through the ticket and so did all the other bit listed above.
Its pretty rust free but would benifit from a good clean.
looking for £100. collection from SWINDON SN2 5JE or could take to Stanford but unsure on which day i shall be there as yet.
If interested please text me on 07825255048 and ill return by calling as soon as i can.I dont get on here as much as i would like to due to a heavy work load at present.
Please check back as more bits to follow.
