- Joined
- Apr 1, 2010
- Messages
- 759
- Reaction score
- 87
- Location
- hayling
- Year of Your Van(s)
- Bay-less
- Van Type
- van
what are the cables/wiring like in the back engine area - lighting circuit wise?
Look pretty good but I can double check
do you have the, intact, indicator switch/assembly?
Yes, I’ll check conditionHi, do you still have the steering column lower fixing plate, the round one with two fixing screw holes? Thanks
I’ll check how many I haveHi, I need 2 of the clips and 1 hazard thanks
Does this bus have the louvred side window opposite the sliding door? What state are the cab seats and the cab headlining in?
Headliner looks pretty good, front seats are aftermarket but good, no louvred windowDoes this bus have the louvred side window opposite the sliding door? What state are the cab seats and the cab headlining in?
Do you have the aluminium curtain track that runs end to end on both sides please
That sounds encouraging. Do u have any photos of the cab seats and their runners, and of the headlining. Where are u located?Headliner looks pretty good, front seats are aftermarket but good, no louvred window
Hi,Apart from the Deluxe Microbus, few if any British specification 1968~79 VW Type 2s were factory-fitted with heated rear windows and none had a rear-window wiper & washer system. My 1973 VW Type 2 already has a pukka rear-window wiper & washer system, but I have yet to substitute the heated rear-window glass.
Ok, thank youI’ll check how many I have
ok cool let me know what it looks like and where you want to do the cut! where it ducks into the firewall would be great if possible - pm a posted price to pe5 please sirLook pretty good but I can double check
Hi, do you have the hardboard sound deadening panels in the engine bay still? Thanks
Already soldHi, do you have the hardboard sound deadening panels in the engine bay still? Thanks
Morning @davidoft !
Any chance you have an interior lights switch?
Doesn’t matter if it doesn’t work as all I need is the escutcheon plate that fixes it to the dash
Thank you!
Ben
Are the engine mounts for the moustache bar still on the chassis please?Already sold
Thanks for the reply. Am all sorted now.It does but it’s all working
