Hi, I can see the outer door skins are rotten is the bottom inner of the RHS door any good? Id be interested if it is to repair my door.
Also Price on the steering box and headlights (if they are RHD and matching Hella) please
That bus looks so sad with its wipers dangling down
Do you have any pictures of the rear, of the inside as well as the cockpit?
Unfortunately not
Do you have the clamp that holds the jack under the passenger seat? Looks like this:View attachment 2581
Hi, I need 2 of the clips and 1 hazard thanksHazard switch yes , heated window no , little metal bits yes, how many ?
Apart from the Deluxe Microbus, few if any British specification 1968~79 VW Type 2s were factory-fitted with heated rear windows and none had a rear-window wiper & washer system. My 1973 VW Type 2 already has a pukka rear-window wiper & washer system, but I have yet to substitute the heated rear-window glass.Hi, do you have the heated rear window switch or hazard switch? Thanks
