Elliott99
Hi, should the earth of my 240 volt hookup be bonded to the chassis of the van, or does it just float, only connected to the incoming wiring?
Thanks,
Elliott.
Thanks,
Elliott.
Steve B said:No, it shouldn't.
The 240v connection should be max of 16amp and RCD protected. In no way should it be earthed to the van.
Any fault and essentially you are risking making the chassis live, along with frying the 12v.
SEe it more as an internal extension lead that is fused.
