Empi gear lever questions
montypsx
Jul 7, 2011
510
2
donny
Hi all just been give an empi trigger gear lever brand new off my mate that he's had for years and never used it. My question is what else do I need to fit it in my van all he's given me is the gear lever he says there was some other bits but he can't remember what they were. So any advise please on what I need or how to fit it would be brill. Many thanks phil
I had one of these a while ago, big improvement over standard once you've played around with it. It should have a spacer, which raises it off the floor by around 10mm, and 2 longer bolts to bolt it down. The bolts will be available from a hardware store and the spacer will be simple to fabricate. Have a look on one of the web shops that sells them, Coolair, Heritage, etc and they will likely have pics and extra details to help you.
As above, they come with 2 different sized spacers and instructions to determine which one to use, I can't remember the criteria for each unfortunately, best bet would be to place the ball in the gear linkage and measure.
Cheers guys I'll have a look if it's only a spacer and a couple of long bolts I think I can rise to the challenge lol. Thanks for the replies
