empi quick shift
streetboy
Mar 8, 2008
878
surrey
Hi all, I'd like to know how these fit, and if they actually do significantly reduce the movement of the original gear lever?
Thanks in advance ;)
This was the first thing i fitted to mine, deffo worth the money and they reduce the throw bewteen the cogs by 40% :D
Must admit though me and the old man had a massive arguement about how it goes though :lol:
I want a locking Gene Berg shifter now but i'm poor so i can't :(
mine came with one on and must say excelent,gears much closer and simple as to fit....
Thanks fellas, I can only assume you remove the grear lever, place the plate onto the cab floor, replace the original bush with the one suplied, and then rebolt the gear lever with the two new bolts supplied?
...something like put into 2nd maybe 1st gear remove original stick....fit spacer (one of the two supplied different thicknesses) screw stick down....check you have all gears...jobs a good un
8)
Thanks mjknight71 ;)
Think I will buy a bush kit for the linkage system back to the gearbox, and make sure all the play is taken up first. Is this a tricky job?
