StevieNicker
I wasn't convinced the Earlybay id just bought was running on all 4 so I thought Ii'd do a compression test.
Its a 71 but has an 1800 type 4 engine in off a later model.
Compression result were as follows:
Cylinder 1 (OS Rear) - 85
Cylinder 2 (OS Front) - 110
Cylinder 3 (NS Front) - 90
Cylinder 4 (NS Rear) - 85
As you can see 3 cylinders aren't playing ball. I re ran the tests for 1,3 and 4 with a bit of oil in the cylinder to see if was a piston ring issue. Re-run results were as follows:
Cylinder 1 (OS Rear) - 120
Cylinder 3 (NS Front) - 115
Cylinder 4 (NS Rear) - 170 (WTF!)
To me that points to worn piston rings, but with 3 being gone would you think it could be something else, i.e the Head or valve issues?
