lobtronics
Active member
- Joined
- Apr 1, 2011
- Messages
- 39
- Reaction score
- 0
Hi All,
I have recently bought a 1972 van and would like some advice on oil breather pipes. Below is a picture of the engine and the oily engine lid.
As you can see there is no breather pipe on the oil filler. I am assuming that normally the oil breather would connect to the air filter, is this right? I think the air filter I have isn't the standard VW one and I am guessing the tube at the bottom, of the filter, should connect to the Oil filler.
Could someone give me some advise on whether I should fit a connection pipe and if not should I block off the one on the the air filter as it is bypassing the filter
If i need a connection pipe, could you recommend where I get one from as well please?
